fix or cut
Originally posted by The Lang-Shankit Scunner View PostAh yes, im being non-observant (if thats a word) and rather stupid yet again. Itll at least create a space for a lunch box that you can keep food warm in.
thats cause you dont create enough speed to force fresh air into your cab
stale air = brain festering
Youve never considered upgradin to a 2.4?
if i get any speeding tickets i will consider buying a 2.4
Originally posted by chrisinflight View PostThe bolt to undo is the long adjuster bolt which is holding the curved bracket.
Loosen this bolt, slide the compressor down a bit and slide the belt off. You can then remove the pulley, bolt and the bracket. The compressor stays fixed in place.Only Toyota can get you out of shite
Originally posted by gwh200 View Postfix or cut fix or cut fix or cut fix or cut fix or cut fix or cut fix or cut fix or
cut or fix or cut or fix or cut or fix or cut or fix or cut or fix or cut or fix or ............
got it dave...........burn itwhen did you say your winch plates arriving??
Originally posted by joker?? View Postferking hell !!! way its going you should have gone to 4x4 r shite
mind you it has taken a while,wished i had ,had the one made iwas going to in the beginningNon intercooled nothing.
