Originally posted by Apache
View Post
4wd on 3ltr - help please
Hi MateOriginally posted by MudSurfer View PostHi Andy (2) God, we are everywhere!
Cheers for the offer - not sure if the manual system is the same as the one on the auto......and it's quite a drive in this weather - you could always come to Avon Dassett - if the thing above works, then I can have a play, then look at how your 4wd is piped and see if mine will stop playing silly buggers....
Got a little issue with rear brakes to sort out in morning first, Rain stopped play today
only have to tap brake pedal at moment and rear locks up, tis the best they've ever been since i've had it
Give me a call if you want to meet up on 07785 902117, i'm coming down to Junction 12 M40 Monday am and should be free around 11:30 ish if that helps
Thanks for the offer mate, I'll be safely tucked away in my office on Monday.....hope you sort the brakes, my front ones need doing, was going to do them today, sod the rain, but got stumped (again) with this 4WD issue...Originally posted by AndrewC View PostHi Mate
No, you get 4wd whatever position the button is in using low4. Either that or my truck is broken - in a good wayOriginally posted by MudSurfer View PostI thought that only worked when the 'sleeve' was across the front axle, which the ADD actuator makes happen..????
Thinking about it - wonder why?Cutting steps in the roof of the world
did my front brake pads today,29 quid!bargainOriginally posted by MudSurfer View PostThanks for the offer mate, I'll be safely tucked away in my office on Monday.....hope you sort the brakes, my front ones need doing, was going to do them today, sod the rain, but got stumped (again) with this 4WD issue...
None of them are blocked off now - I have the pipe that comes from the alt. (I assume) that goes to the front of the 'switch/soleniod' but this is t'd and the other spur goes to the top of the cylinder thing, then the next outlet on that goes to the bottom of the cylinder thingOriginally posted by Apache View PostMight be easier if you tell us which one is blocked off, then I can tell you where its supposed to go.
I'll show you on Saturday!Too old to care, young enough to remember
Yer 'tis!Originally posted by Apache View PostCan you send me the details of the MAC sticker again? Cant seem to find it only a couple of days after you last sent it!
http://www.hiluxsurf.co.uk/forums/sh...t=40944&page=2Too old to care, young enough to remember
D
lolol
