hi chaps got a problem with my rear window, i comes down on its own ,i can get it to come back up after a while and say 15 to 20 minutes later its back down again ,has anyone got any ideaswhat could be causing this and is it an easy fix cheers.
rear window
Do you need to help it shut from out side somtimes?Originally posted by brian88883hi chaps got a problem with my rear window, i comes down on its own ,i can get it to come back up after a while and say 15 to 20 minutes later its back down again ,has anyone got any ideaswhat could be causing this and is it an easy fix cheers.
Could be moisture on the key switch in the tailgate causing a short circuit, or the relays are 'acting up' in the module box behind the rear side pannel, next to the left side cubby hole/box.
Sorry can't help with that as it sounds like what Busshwhacker saysOriginally posted by brian88883no just a click but it done this earlier and i managed to get it back up not sure how though just fiddled a bit but its came back down on its own.
Have you tried spraying the circuts with WD40
Maybe this will help....
http://www.hiluxsurf.co.uk/forums/at...0&d=1134208703
You can get replacements from Maplins-------JM67X 12V/12A Mini relay
I've done it. Piece of pi55 (to quote the best Welsh film ever). Cost me about £3 though and an hour of time in total.Originally posted by yoshieFor £2 a pair,But don't you need a puller to get the relays off the board Vince?
Forgot to say; if you need a solder sooker, I've got one.Do you know that, with a 50 character limit, it's
