the off side rear anti roll bar linkage seems to have broken. looks like the top nut/washer has corroded and the link bar dropped through the bracket.
do you normally replace the whole assembly?
Is it worth doing both sides or even buying both sides assuming the other side may go in the near future?
Where would be the best supplier and is it an easy swap ie any special tools required?
thanks in anticipation of your advice...
