Truck casualties from The Plain.....
  • Truck casualties from The Plain.....
    Me first...
    Slid into the side of a deep rut and creased the front wing - then really trashed it when I opened the door - ouch.
    Coming down the M4 a sudden growling, rumbling vibration from the front which is still there after 100km's - sounds very very expensive.
    Sometimes I hate The Plain.
    Any other truck damage guys????????
    I did almost all of it in 2WD as my poxy 4WD still doesn't work, and judging by the pics of the post luncheon sessions - I made the right decision to go home....
    No damage to the truck, at all - but do have my belt squeal back again.. (or maybe that was just down to me eating too much )
      Crunched my wing but not as bad as boyo and the power stearing belt is slipping
      www.daemon4x4.org
        i got no damage, but the plain did fix my rather loud squeeling turbo, it's as quite as a mouse now and more power
          The little known healing properties of the plain - respect the plain, and it will fix your turbo...
            and destroy your clutch
              well a quick look over the truck and the only damage is even more dented front valance. Fixed tomorow with an angle grinder if the weather's good. Other damage is a bruised arse after landing on it lol. Still could have been worse, I could have rolled the truck if GWH hadn't towed me back
              Hold my beer and watch this
                I'm praying Hippo is ok, she overheated on way home
                A huge thanks to Summinelse for providing sustinence.
                AA arrived in 1/2 hour and found her about a litre short so topped her and home I came, but oil pressure is showing low
                Will go and check oil in morning -
                  had my own xmas lights [alternator]managed to get them off at countess and stayed off ,overheating !!!temp went right up managed to wash out rad at service station , cheers to gwh for being my escort part of way home , ian for the wd40 ,@everyone for helping
                  ps nearly got sideswiped by some old fart in a roller on the 316 stupid barsteward just come on 316 then pulled in to next lane where i was travelling
                  was a matter of a couple of feet macho's really held the road well
                    same here trev oil pressure was just off the pin
                      Well apart from the cartridge .....the truck has just dumped a load of oil....Front crank seal is suspect got to go out into the cold to find out now
                      www.daemon4x4.org
                        Jeez, not more troubles Ian?
                        Your truck will be like new soon with all the replacement parts!
                          Bash plate is off and it's the crank oil seal
                          Well the cam belts got to come out so i'll get the injector pump in at the same time .........Just wish it was warmer and more daylight
                          www.daemon4x4.org
                            Oh and vince this is replacing a replacement
                            www.daemon4x4.org
                              The seal? I guess your crank bearings are knackered too then.
