Whoops, stocked up on veg oil for crimbo visits... off to the in-laws so without thinking topped tank up with 45ltr of veg oil. Drove off with the kids in the truck following the wife in her car we were getting rid of it (her car) as become very unreliable. She set of first then I after a bit followed. I was struggling to get the truck upto speed then to my horror on the first hill the truck started to loose power and ended up crawling up the hill at 30kmph... got to the top and started to get better then ran fine. Then it dawned on me that I was running on almost 100% veg oil as 15lt of fuel already in was on a 75%mix of veg oil . I have not put any derv in and it's running fine..!! is this doing any unseen harm ??
100%
i put in this time of year about 45l of veg with white spirit and fill up with fuel.I've got no heating mods at the mo and the truck seems to run ok after a couple of mins when its warmed up.I put the W/S in the veg oil drum and give it a good shake up first so its well mixed up before putting into the tankOriginally posted by madcampbellDo you just run veg oil and nothing else? ok plus the white spirit...!
No heating mod or anything else?
Do you get the lack of power for the first 3/4 mins
Cheers Markhttps://www.facebook.com/groups/henpals/
I take it the WS is t thin it down?Originally posted by stormforcei put in this time of year about 45l of veg with white spirit and fill up with fuel.I've got no heating mods at the mo and the truck seems to run ok after a couple of mins when its warmed up.I put the W/S in the veg oil drum and give it a good shake up first so its well mixed up before putting into the tank
how much does it cost WS per ltr?
i get the b&q cheap stuff in a 4l container and i think its a couple of quid but keeps the oil thinner as you say.If you mix some in a drum of oil and give it a good mixing and leave it over night you can see the difference between mixed and unmixed oilOriginally posted by madcampbellI take it the WS is t thin it down?
how much does it cost WS per ltr?https://www.facebook.com/groups/henpals/
Thanks, will try that and put them out on a cold nigh to see the differenceOriginally posted by stormforcei get the b&q cheap stuff in a 4l container and i think its a couple of quid but keeps the oil thinner as you say.If you mix some in a drum of oil and give it a good mixing and leave it over night you can see the difference between mixed and unmixed oil
Blumem heck from what I have read so far we can run our trucks on a number of diffrent blends of......Originally posted by AlbannachI'm running 20L Veg, 2L Unleaded and 28L Diesel just now. Rough as a bag of ferrets for the first 5 minutes in the morning, after that it's fine.
SVO, white spirits, diesle, Unleaded,WVO, bio diesel........wow
I popped me pump seal on 50/50, reduced it right down and it's stopped so till i get the second heated tank up and running and a new seal it's staying a thin mix, sodding stuff's expensive enough with out dripping on the road,Too young to die and too old to give a toss
