Hi Guys Just Been Told That English Diesel $$$$s Your Seals Up On The Diesel Pump And As Mine Is Leaking I Either Have To Pay Over £1.000 For It To Bo Re Conditioned Or Try And Find One Very Cheap Somewhere So Basically Im On The Hunt For A Very Cheap Diesel Pump Must Be In Excellent Working Condition If Anyone Has One Please Can You Give Me A Call On 07972267016 Asap Please Guys Cheers Chris
fao bushwacker
Originally posted by chris barnesHi Guys Just Been Told That English Diesel $$$$s Your Seals Up On The Diesel Pump And As Mine Is Leaking I Either Have To Pay Over £1.000 For It To Bo Re Conditioned Or Try And Find One Very Cheap Somewhere So Basically Im On The Hunt For A Very Cheap Diesel Pump Must Be In Excellent Working Condition If Anyone Has One Please Can You Give Me A Call On 07972267016 Asap Please Guys Cheers Chris
cheers shaunNO LONGER A SURFER NOW DRIVING A LEXUS
What year is your truck? fill in the details under your user name.
I'm assuming you have a 1989 2.4 or non EFI if you've been quoted 1000 quid.
It's not the diesel that $$$$'s the seals, it's the age of them plus veg oil use. seals can be replaced quite easily an relatively cheaply, if a little time consuming, provide you have an EFI engine.
I've sold my pump to Woodzie BTW.
Originally posted by BUSHWHACKERWhat year is your truck? fill in the details under your user name.
Originally posted by chris barnesi have a 2.4 92 model how do you put your car details on mate
A 92 wont be the mechanical pump so should be cheaper/easier to source/repair etc!
An up in the top left of the screen look for 'user cp' once your in there theres loads of Edit options! an you can find details in there mate!
Heres how to replace the top seals on the EFI pump, they're the seals that usually leak through veg oil use...........
http://www.toyotasurf.asn.au/techsite/fuelpump.htm
p.s. that link shows the pump removed, but they can be changed without removin g the pump.
Originally posted by BUSHWHACKERHeres how to replace the top seals on the EFI pump, they're the seals that usually leak through veg oil use...........
Originally posted by chris barnesive been told its the main seal on the front by the cam thats leakingDo you know that, with a 50 character limit, it's
Originally posted by andy62Get the kit from Roughtrax (about a tenner delivered) it has all the seals in it.Last edited by chris barnes; 10 December 2007, 14:59.
