Originally posted by henry F
Side steps
Little garage that fitted matrix don't have a pressure device,
whats best option testing wise?
would a radiator place be able to do a test before I remove rad,
would it show a leak up as a stream of water jetting out somewhere,
or bubbles or something?
I sc.raped all the white stuff off, you will then get a better idea of where it's actually leaking from as after a few journeys you'll see fresh fluid rather than white gunk, i dried the area around the leak as best i could while the engine was hot and soldered directly over the leak...Originally posted by henry FThe main radiator has a build up of what looks not unlike
battery terminal powder type gunk, along the seam on top front,
where it runs across front of car cross member bonnet catch thing.
...still leaks but hey I tried
Check what price you can get the rad recored for, my local place is only £25 or so cheaper than a new rad from roughtrax.=========
=SOLD UP!=
I've not got a big soldering iron anymore to sort the leak out.
Certainly I can see water dribbling out from a tiny split in the front edge
With the break coming up after Christmas, if a removal of the rad' is easy, then I'll break out the spanners and take it off,
Sure I had a quote for about Eighty Quid a re-core, does that seem tooooooo high after all?
£80 is a good price for a recore, my local place wanted just short of £140, a new rad from roughtrax is £165 +VAT http://www.toyotahilux.com/?doc=11&cid=149 so for £80 i'd go for a recore, but if a recore was gonna be £140 i'd buy a new rad.
I haven't had the rad right out yet, but it's only nuts and bolts so not too bad a job
=SOLD UP!=
