Our kids PC has died and we don't know why
  • Our kids PC has died and we don't know why
    Help! Calling all computer experts out there......we left the other PC on as the disk was defragmenting and went back to it after returning home from paintballing and it won't boot back up. It makes an intermittent alarm noise which goes on for about 5secs a time and the screen remains blank. I've tried pressing ctrl alt and delete, nothing, the monitor, keyboard and mouse are all fine. Is this terminal???
    www.daemon4x4.org
    Switch off the mains power to the PC (pull the plug) leave for 30 secs re-connect and restart the PC.
    I'm no expert by the way!
      If mine messes me around, I turn it off on the button on the tower... Just give that a shot.
      I know someone will come along an say thats bad - but lifes to short to be waiting for a computer to make up its mind!
        Tried that and it's still deceased
        www.daemon4x4.org
          Ok, as you power up, press and hold F8, it should go into safe mode, see if that works.
            As long as there isn't any data being written to the hard drive, and as a last resort when all else fails, it's normally okay to do a hard power down.
              No that didn't work and we have lost the hard drive light as well
              www.daemon4x4.org
                Try it with a different monitor, if it's still down I would look to changing the PSU first.
                And that's a job well within your range of skills old bean
                  "intermittent alarm noise" is an error code.
                  Try
                  reseating your memory or/ and video card.
                  If that does not work try removing one stick of memory at a time (if you have more than one) to see if it will boot then.
                  I Love Wales
                    Internal fuse or battery, thats as far as I can go.
                      Had a wiggle ....looks like a HDD fault
                      www.daemon4x4.org
                        Hmmm, no hard drive light eh? May be a hard drive crash while defraging ,but then again the hard drive light normally only illuminates when the hard drive is being accessed. Do you have another computer at hand where you could mount the hard drive as a slave just to check that it is functioning?
                          Is it making a noise, are the fans spinning?
                          It will still boot if the Hard drive is U/S
                          I Love Wales
                            Only the bleep ,fans are spinning every thing else blank and no boot up
                            www.daemon4x4.org
                              thats beoynd me .........wiggleing things are my limit
                              www.daemon4x4.org
