I've put 40% veggie oil in my surf today, is that too much for this time of year?
40% Veggie
Narp, going for ceramic (PTC) heaters, as they are nicely self-regulating; once the coolant-exchange gets going (and installed -- but that's another story), they gradually use less and less current, but keep bringing the fuel to the same temperature.Originally posted by POPEYEWhat heaters are you after? the tape type?
Right! dont know about them, have you any info/pic of em, i'm halfway through sorting out the heating(water) thought about doing the small swirl tank thing so it's got a ready warm ammount to get going on, but for the moment it'll have warm up on deisel,Originally posted by cataclysmNarp, going for ceramic (PTC) heaters, as they are nicely self-regulating; once the coolant-exchange gets going (and installed -- but that's another story), they gradually use less and less current, but keep bringing the fuel to the same temperature.Too young to die and too old to give a toss
I've been ripping them out of "Ceramic In-Car Heaters" like this :http://www.maplin.co.uk/module.aspx?...8775&doy=27m11Originally posted by POPEYERight! dont know about them, have you any info/pic of em, i'm halfway through sorting out the heating(water) thought about doing the small swirl tank thing so it's got a ready warm ammount to get going on, but for the moment it'll have warm up on deisel,
Gonna use one (double element) to heat the fuel before the filter, then one each on the injector lines. They dissipate about 50W per element, and are about 80% efficient.
Cheer's, thats a good idea, i made this exchanger to go just before the engineOriginally posted by cataclysmI've been ripping them out of "Ceramic In-Car Heaters" like this :http://www.maplin.co.uk/module.aspx?...8775&doy=27m11
(via the 6 port valve) it's hot after about ten minuits of running but those heaters will dam near give you immeadiat start up on vegToo young to die and too old to give a toss
This is hippo's heater - if you get one tell them you want the 10mm pipes.
There is at least one more member here with the same heater.
TrevLook out Eastbourne, the Pandas are coming !
This is my progress so far, i did a couple of 8mm copper coils but as i had a job to blow through em i decieded to re do em in 15mm, i still have an 8mm round the svo filter tho, it's mainly to help prevent line looseing heat it's already picked up from the fuel tank, it's then bumped up in temp by the exchanger, once the motors up to temp everthing should be fine, but as you say it's the first minuits that are the problem
http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=36706Too young to die and too old to give a toss
i used it pure with no problems at all
ran a xanta for mounths on it and i tryed the surf on pure its all right but a bit lumpy on a cold morning
i am ready for a new mix to run it on veg oil againam not die lex sick its you that cant read mate
Same here with 50/50, the lang shanet-scunner's been trying white spirit in the mix and reccons it works wellOriginally posted by JUDWAKi used it pure with no problems at all
i am ready for a new mix to run it on veg oil againToo young to die and too old to give a toss
Update on that, i have switched to unleaded now cos the power difference is much better, i have a conversion for 100% but this time of year in order to switch early 10% unleaded helps.Originally posted by POPEYESame here with 50/50, the lang shanet-scunner's been trying white spirit in the mix and reccons it works well
Popeye is now the master craftsman (sorry Craftsperson) on veg systems, but if you want a quick easy basic one unit solution, then the vow2-DW works well, it has electric heating and then when water is warm switches off and lets coolant do the work.
Youll find it here:
http://www.vow2.co.uk/ordering.htm
7th one downWithout Surf And Unhappy
