Gps
  • Gps
    what do i need to get a laptop to run memory map and GPS
    and yes i know i need the memory map software
    www.daemon4x4.org
    A GPS reciever, and the software to run the mapping,
    Without Surf And Unhappy
      A laptop!
        What type and where from??????
        i am not very good with computers ......just plug and run is my limit
        www.daemon4x4.org
          Heres one without searchin for long
          http://cgi.ebay.co.uk/GPS-RECEIVER-R...QQcmdZViewItem
          That should come with its own soft Plug and play, and your mapping soft should detect it, i.e your navigation program should detect it
            Right now i understand, i thought it was more complex than that........Thanks chap
            www.daemon4x4.org
              No probs but a stand alone system would work better, as in your pm.
                Depending on your laptop - I think, the GPS settings in Memory Map if you use a USB GPS receiver may need some playing around - I think mine is set to COM 9...dunno.
                  Will have to research more and get Melons ( the expert) to sort out
                  After all its for plotting the routes on the plains
                  www.daemon4x4.org
                    woodzie here ya go all ya need to know about what will run it and what will run it
                    http://www.memory-map.co.uk/
                      Ah that helps too
                      www.daemon4x4.org
                        Ah that helps too
                        you should be able to find all the systems it runs on without any prob's
                          Gps Software
                          If you have a garmin gps, you can download the latest version of mapsource for free from there website.
                          To interface most modern gps's to a laptop is pretty easy, if your gps has a usb cord its simply plug in and play.
                          Have a look at this link there's some basic info, technical, further links etc
                          http://www.exploroz.com/OntheRoad/Na...gSoftware.aspx
                          Cheers Matt
                          Harden the Fuk Up Princess
                            I'm running memory map on a laptop with a garmin geko gps unit plugged in.
                            With this setup it will track & mark current position on the map as I drive.
                            Apart from the geko I needed the garmin data lead & usb-com port lead (got both of ebay for about £5 each).
                            If you do decide to go ahead and have any problems give me a call.
                            My other cars a QUAD
                            (sv1000spilot on surf forums)
                              Garmin Gps Software
                              If Youve got a usb cord then all you need to do is download from the garmin website the enroute operating program which is free and run it through you laptop. It does current position, tracking etc
