How clever are you?
  • #76
    Originally posted by Antshiel
    2+2x2=......
    Well as you've written it the answer is 8....to make the answer 6 you would have to write 2+(2x2)
    HELEN xx
    • #77
      BODMAS makes it 6, to make it 8 you'd need to put the brackets (2+2)x2=??
      =SOLD UP!=
      • #78
        Originally posted by Apache
        Lets see if we can blow up the server....
        Square root of -1?
        That's easy, it's i.
        D'oh, waay too slow.
        (back to sleep)
        Paul </Slugsie>
        Immortal.so far!
        • #79
          ok, work this one out then people...
          if the sound of yellow remains constant through the path of the Bolliton Belt (sector 5, not to be confused with the sub-quandrant sectors in the minor system) and merges with a Senimet 6 at an angle of 12 degrees - what is the resulting burnoff in time factors as defined by the purple dot i can see in my right eye?
          • #80
            That's easy, it's 7.
            NEXT!
            Paul </Slugsie>
            Immortal.so far!
            • #81
              NEXT!
              you obviously didn't calculate into the equation the walls sausage theory of evolution through cream donuts!!! dumbass!!!
              • #82
                But I believe you'll find that, as written, the answer is indeed 8. The parantheses placement are open to interpretation, unless they are implicitly specified. If none are specified, it is quite valid to work on the first and shift right, so to speak.
                • #83
                  Without you telling us the weight to mass ratio, that's a trick question.
                  • #84
                    try these
                    http://www.prechel.net/fun/clever.htm
                    • #85
                      http://www.mathsisfun.com/operation-order-bodmas.html
                      it was originally written
                      2 + 2 x 2 =
                      =SOLD UP!=
                      • #86
                        what's wrong with you dude??? i was just playing! everyone knows the Bolliton Belt is in sector 17 - not 5!!! and you're asking about weight to mass ratios???
                        dumbass!!!!!
                        • #87
                          Originally posted by stormforce
                          no you never.....your just trying to worm your way out of being nominated now
                          nah i aint doing 2 weeks in a row m8 lol
                          • #88
                            2 + 2 x 2 =
                            Just the first match from Google posted as an example, but one will note that in certain areas of training, the BODMAS technique? isn't the defacto:
                            http://www.angelfire.com/pa/baconbacon/page2.html
                            Assumptions are open to interpretation, therefore not specifying the order isn't a valid method other than in general math.
                            And no, I ain't going to try remembering all the equation theory just to prove this point.
                            • #89
                              dumbass!!!!!
                              Aah, I thought you wrote the Bolton belt.
                              • #90
                                if you're too lazy to do what's needed to prove your point, then...erm...i don't know, i can't be @rsed to finish what i was going to say...
