Speaker wire and EF Interference
  • Speaker wire and EF Interference
    I'm finally getting my house organised.....and today I'm wiring up my speakers, but I want to put the speaker wire and an electrical cable (that goes from the socket to a power bar in a cupboard) in the same trunking along the skirting board - is there likely to be any EF interference problems with running them all along the same trunking???
    TIA
    TIA
    not really sure but some new units i was told will let you as some dont pick up interference like the old speakers or stereo's did. or you could run speaker wire under the carpet so they both seperate
      Cheers Will - I thought about putting it under the carpet, but can't be bothered moving everything - must be getting lazy in my old age...
        n dont forget m8 you get that cable thats flat like tape for your speakers etc so no bumps under carpet!!!!!
          u wont get interferance with modern stuff
            I've got the stuff that came with them, quite thick but flatter than normal wire.....big cable, tiny speakers.....
              If its a decent stereo and the output impedance is low, it should be OK. It's hard to induce current into low impedances. So if you dont coil one around t'other, you should be OK.
                Denon CD/Tuner going to Bose speakers.....
