but im after some engine tech info for a 3y engine,basically the head bolt torque,valve lash settings,ignition timing setting,points gap.spark plug gap.anything ive missed?? im in the middle of building a head for the 1st gen as the valve stem seals have given up the ghost after the little escapade over the wkend.and while ive got the engine stripped down i might as well give it a good service.so can anyone help.
i know this should be in the tech section.
Originally posted by surfensteinbut im after some engine tech info for a 3y engine,basically the head bolt torque,valve lash settings,ignition timing setting,points gap.spark plug gap.anything ive missed?? im in the middle of building a head for the 1st gen as the valve stem seals have given up the ghost after the little escapade over the wkend.and while ive got the engine stripped down i might as well give it a good service.so can anyone help.
I think Yotatech will have the answer, as they seem to have more petrol engined trucks over there.
You kept that quiet ........be have both suffered ......uj no 3 this yearOriginally posted by surfensteinbut im after some engine tech info for a 3y engine,basically the head bolt torque,valve lash settings,ignition timing setting,points gap.spark plug gap.anything ive missed?? im in the middle of building a head for the 1st gen as the valve stem seals have given up the ghost after the little escapade over the wkend.and while ive got the engine stripped down i might as well give it a good service.so can anyone help.
This is bad i killed a first genwww.daemon4x4.org
i was a bit concerned that the poomobilwas using a litre or so a wek,but the oil filter had a defect and was not to tight in one spot.has not used any oil for a month nowOriginally posted by surfensteinits ok i dont think it was the plain although the water didnt help.the engine has been smoky for a while now and drinking oil at the rate of a litre or so a week.so i think its the stem seals.
Non intercooled nothing.
