Bad news
  • Bad news
    insurance has written my surf OFF! so i will see if i can fix it i need some panels, frnt driv side dam, so need inner + outer wing, fnt panel & ,maybe some suspension parts, wheel looks like it was pushed back a bit.also the airbag went off, {not bothered about a new one } Can anyone help, i love my truck & dont want a different one ,has anyone any contact's for any of the parts I might need. fingers crossed cheers JIM
    Sorry dude but every cloud and all that. Try flebay there's normally shed loads of stuff on there.
      Also try Parts gateway on the internet ....it might help
      www.daemon4x4.org
        check roughtrax and milners too mate, both do body panels
        =SOLD UP!=
          Chillitt has a shed load, I've seen it!
          p.s. Whenever Sally traffic says something about chaos on the roads caused by a shed load, I often think, "A shedload of what exactly???"
              Silver lines for clouds.
                Having had mine written off and rebuilt, as long as you can get the parts & get them fitted you should be ok. It might be worth getting someone to check that theres no major damage that will end up costing more to repair than the insurance will give you.
                Keep all receipts & if possible take or get pictures taken as the work is done.
                Biggest pain I had was getting the VIC after the work was done.
                Have found both of these usefull in the past
                http://www.breakeryard.com/
                http://www.breakerlink.com/index.php
                My other cars a QUAD
                (sv1000spilot on surf forums)
                  If you get totally stuck you could give a friend of mine a call Mike Ribbons Brockford Motor accident repair centre Needham Market Suffolk.
                  He can get anything you need and is very reasonable sorry don't have his number to hand at this moment.
                  Good luck with it parts are not that expensive and if your doing it yourself it will be worth it.
                  Do you have someone who can check the alingments before you start.
                  Cheers JB
                  www.brydenenterprises.co.uk www.kirstyskids.org
                    parts
                    the surf,s in a mates garage, he will be doing the work, i,ll just be the gofor. cheers jim
                      This company seem to have a couple of 3rd Gens, might have some of the bits that you need.
                      http://www.equicar.co.uk/breakers/br...ubmit=Go+-+%3E
