crystal front indicators?
  • crystal front indicators?
    went to clean the mud out of my front indicators today,and found massive holes cut in bottom,so washed out,then spent fookin agaes faffin with the bulb contacts and now working,so they will need replacing,but me being me i want the crstal clear ones,ie not just clear like it already has but the see thru lenses with no pattern apart from reflector(yes i know not strictly legal lol)any ideas anyone,can find any on flea bay?
    also went to fit the a bar today,found the reason it didnt have one fitted!,offside holes----one has no thread,other has a snapped bolt in it!!!,so trip to welders me thinks to get bracket welded to chassis!!!
    Cut the plastic lens off and cover with cling film, et voila, don't come any clearer than that
      I've got these with LED bulbs
        http://www.carstylingstudio.com/erol.html#11850X0
        Give these fellas a call, they might be able to help you. Or TonyN, forgot he sells clear lights too.
          cheers for reply guys,last link they look like they have some but error on page!
            i have crystal clear lens on my truck but they are off a 3rd gen they fit with a little modding look pretty good as well .
            cheers shaun
            NO LONGER A SURFER NOW DRIVING A LEXUS
              cheers shaun
              Where did you get "crystal clear" lenses for a 3rd gen?
                http://www.toyotahilux.com/?doc=11&cid=168
                I thought you were trying to save money!
                  i am but cant leave them like that!and lights on that link have the patterned lense
                    They're not crystal, only clear.
                    Curiosity killed the cat, not the business venture
                      got mine off ebay for £20.00 the pair but they dont half look good and mine went though the mot with them on.
                      cheers shaun
                        cheers shaun
                        how u make them fit??
                          cheers shaun
                          And they're definately crystal clear(no pattern on glass, can see bulb),
                          not just clear(clear glass but obscured in inside, can't see bulb).
                            i screwed one side in one of the hole already there and then drill a hole the other side and put a self tapping screw in and then made up a small plastic insert to fill the gap you would have to look really closely at them to notice they are not factory fit.
                            cheers shaun
                              And they're definately crystal clear(no pattern on glass, can see bulb), not just clear(clear glass but obscured in inside, can't see bulb).
                              yep you can see then bulb and the crystal cut reflector behind it.
                              cheers shaun
