Managed to get my ar5e into gear this morning after a heavy night of drinking!
Jacked up the truck and gave the wheels a rock, offside okay apart from movement on steering bar(?) this bit anyway -
![](http://i168.photobucket.com/albums/u183/Copycat_uk/play2.jpg)
nearside also has play at same points -
![](http://i168.photobucket.com/albums/u183/Copycat_uk/play4.jpg)
is this play normal?
Inspected and clocked the brake disks, both of which were in good condition with negligable run out, pads as new.
Nearside wheel had a fair amount of play on the bearing so decided to give the nut a nip up. Unfortunately my hubs look a little different to the ones in the link posted by Vince.
![](http://i168.photobucket.com/albums/u183/Copycat_uk/wb1.jpg)
Mine have studs with nuts on them instead of bolts and beneath the nuts are tapered collars making it difficult to remove. I tried to jack the retaining collar(?) off but only succeeded in snapping a bolt in one of the holes, will have to wait until I get to work tomorrow and bring home my stud extracters.
Anyhoo it looks like the nearside wheel bearings are loose or worn but can't tell until I get at the
