Got a real problem here, it's been there a while and thick sh!t that I am I've been ignoring it. But now it's got to the point where I must have something done a.s.a.p.
Front end has a wobble, feels like wheels are out of balance but I've had that checked. Another symptom is if you rock the steering wheel very gently side to side you can feel a vibration travelling up the steering column.
Worst of all is when you brake, it feels like the front end is going to rattle loose! The Surf had new pads and disks fitted last September and it's been fine for months. I have wheel spacers fitted but it did the wobble thing before that, but only when braking.
Now to make matters worse sometimes when I brake it feels like something moves. It's hard to describe but it's almost like the brake caliper or the pads jump forward a touch! This doesn't happen all the time, only occasionally.
I know I should have my ar5e severly kicked for letting this go on for so long but I need to get this fixed now!!!
I'm taking the wheels off tomorrow and I'll be using a dial clock indicator to check for run out on the disks and any obvious damage, can anyone give me any further advice what to look for while I'm under there? Could the steering idler arm be worn and would that cause a judder when braking?
Any help greatly appreciated (and no lectures please on how stupid I've been for letting this go on for so long).
Thanks in advance. Jim.
