Looking at the EGR valve mod for my 4runner 3ltd 1995.
The truck runs great, good power/no smoke, so a bit apprehensive on doing it but reading the write ups it seems a sure fire mod to carry out with little or no risk.
I have read the write ups and looked at two different sets of images however mine does not seem to resemble either.
There is one similar shaped valve sitting directly above what looks like the fuel pump/manifold. About halfway up on the right side of the engine
There is a rubber tube coming from it which feeds into a small plastic cylinder (about the size of a 2 pence piece and bracketed off the inlet manifold, filter?) a rubber comes out of this and into the inlet manifold.
Half way up is a tee section with a further rubber tube feeding into an electrical connector again bracketed off the inlet manifold. Not sure what type of control device this is or what function it performs? Has 3 wires feeding it.
So is this the EGR valve and is it safe to pull off the tube and blank off as described elsewhere. What is the effect on the electrical componenent.
Seriously do not want to compromise the existing good performance.
