I've got a City & guilds parts 1,2 & 3 in pneumatics!
Never had to use any of it in the past 10 years though!
i'll post a pic if ya want, think it's 12v as all the accessory stuff was
ive a limited knowledge of hydraulics and pneumatics only in the marine trade.extra heavy duty stuff,im not quite up on smaller stuff and newer technology.gas struts would be ok but its getting the struts matched to the weigh other wise they will go up to quickly and be a right bas..rd to push back down again.i would like to go with air as most people have said if i fit a receiver i can use it to air up and use power tools.i think if the air rams are regulated with mini regulators then i would be able to control the speed at which they lift and also the amount of weight they will lift,by fitting oversized rams this shouldnt be to difficult its mainly the control gear side of it im not to sure of.obviously i would go for an old truck air brake cylinder for the reciever as it has a built in blow off valve,and two spool valves one to raise and one to lower.its just the bits in between.also what would be a good compressor to use.the arb locker one ?????
