It currently runs according to the gauge at 91 degrees, is this normal? under prolonged load it then reads about 97, but receeds very quickly when easing off
My New Temp Gauge, What Temp Should My Engine Be At?
sounds about right to me, the thermostat opens at around 88 i think (or was it 82?) the electric fan kicks in at 97 and kicks out again at 92 so i guess the optimum engine temperature is between the latter two temperatures.=========
=SOLD UP!=
This should give you an idea on what temps are expected.
http://www.toyotasurf.asn.au/forum/v...ic.php?t=14717
Nev
Thanks thats greatOriginally posted by NiftyNevThis should give you an idea on what temps are expected.
NevWithout Surf And Unhappy
sounds the same as mineOriginally posted by The Lang-Shankit ScunnerIt currently runs according to the gauge at 91 degrees, is this normal? under prolonged load it then reads about 97, but receeds very quickly when easing offTim
