Originally posted by pirate-storm
Front drive shafts
Superb carnage!!!! Not seen anyone in the UK break one of those without a locker in the front! Wonder if it got weakened the other time when you whacked the alignment out?
Well done Rich.
Any 2nd gen shaft will fit, do you need one? Tricky part is getting the remains of the shaft out, its held in with a spring clip. You may need to weld a bar to the stub to be able to pull it out.
Respect!
Sledge says he's got a d/shaft i can have and i will replace the bushes and bearings at the same time.If i have any trouble then i'll give you a shout.ThanksOriginally posted by TonyNSuperb carnage!!!! Not seen anyone in the UK break one of those without a locker in the front! Wonder if it got weakened the other time when you whacked the alignment out?
Well done Rich.
Respect!
