yea and with the cv snapped at least it will save on wear on the cv boot.a bit like manual hubs.
I think my WARNs were probably cheaper
Really weird that Rich's 33s rub badly when mine (which are an inch wider) haven't rubbed at all even offroading. I'm sure no two fo these bl00dy things are the same!
<edit> Mark, the bashplate works! My mate did a nosedive from ten feet up in my truck yesterday. Very uncomfortable, and used the front towhook as a spade! Bashplate s$$$$ed, but no truckular damage
mine rub really bad when the tyres are pushed up in the arches.The rear mudflaps have been worn thru aswell from the tyres being pushed in the arches
see i dont mess about mate designed to be bomb proof.and i was gonna use thicker material as well.good job i didnt other wise you could of used it as a bulldozer.
I reckon I could run 35s with only little rubbing having measured the clearances on these at full lock!
Not going to though, cant afford re-gearing!
you haven't got the front valance on tho have you so thats saved some of the rubbing on yours.have you actually had the tyres right up in the arches yet Andy
Had it balanced on the backs, and balanced on the fronts, so pushed up pretty hard. I'm sure there'll be somewhere that will do it but I aint found it yet!
Today there were a few places around the course that really pushed the tyres up but at least i now know what the truck is really capable of compared to what off roading i had done before in it
