One for the IT techies
  • One for the IT techies
    If you wanted Wi Fi in 23 rooms (as in hotel) but one router would not do, as the walls are very thick, what would be another way to do this. Also what would roughly be the cost? The building has 4 floors?
    Thanks Philip
    Still Searching,
    Dick Whittington
    You can install SIGNAL BOOSTERS or Repeaters to extend the Coverage
      iam not that clued up with wi fi
      but like marky said you can boost them up
      it may be just a case of putting it in the best place central to the building
      look up wi fi shopfitters
      home use stuff may be no good for a building of that size
        you could use several WAP's with the same SSID (different channels though) or you can get them (netgeat prosafe etc) that you can have a master and several slaves. some of the new waps have a really good range so maybe try some of them first?
        Tim
          Thanks Philip
          your really considering this small hotel then Phil..Good luck with it
            Its a UK Version of a CHICKEN RANCH
              Don't mention chickens if Joker is around
                Ok i wont mention CHICKENS
                  lol yeah he likes stuffing birds lol
                    Look here for some info http://www.microsoft.com/athome/more...elesstips.mspx
                    http://www.broadbandbuyer.co.uk/defa...ShopGroupID=41
                      Thanks all for info and yes i am interested in the hotel which is in Battle, East Sussex. Bur plenty things to check out before i make an offer for the lease.
                      Thanks Philip
                      Still Searching,
                      Dick Whittington
                        Thanks Philip
                        Good luck with it Philip - my folks ran a hotel in Walkerburn, Socttish Borders for a while, if you want contacts for linens, toiletries and such, let me know and i'll put you in touch..
                        Andrew.
                          Thanks Philip
                          We'll keep everything crossed that everything goes well for you Phillip
                            bite the bulet and hard wire it,
                              As for network stuff - you could do what Andy said, and hardware (just one CAT5 per room) and have the wireless, that way you cater for all - couple of boxes of 305Meters of cable, patch panel or two and some cheap switches that allow VALNS
                              The wireless APs have an RJ45 connection on the back, so they can be plugged into the switches too, then you can set one VLAN per room on the wired network, then you'd need to be a bit smarter on the WLAN stuff as to how to secure it - but Windows would probably keep most browsing down to the local PC anyway....
                              How are you going to charge for it? Will you use a Proxy for everyone to connect through so you can track usage??
