They light up bright red when 12volts is connected to them, and they're fitted to the rear of vehicles and used when visibility is poor, such as in thick fog or mist!
They look pretty much identical to the ones I've fitted to both my Surfs. A few minutes with an angle grinder to cut a hole in the rear bumper (in the middle of the Y shaped bracket), couple of holes for the screws, connect the wiring from the old fog light and jobs a good-un. They've worked well, passed MOTs, and survived my off-road driving (which is no mean feat).
looks good m8 but if you had bigger wheel on back you wont be able to see the one then thinking of putting mine a bit wider that should work
I have only got a single one fitted on the right (as per MOT requirements), and it sits underneath a 31" M/T with no visibility issues. Even a 33" wouldn't be a problem.
