@tonyn plz advise
  • @tonyn plz advise
    tony can you advise on these rear fog lights plz
    http://cgi.ebay.co.uk/Flush-fitting-...QQcmdZViewItem
    I can.
    They light up bright red when 12volts is connected to them, and they're fitted to the rear of vehicles and used when visibility is poor, such as in thick fog or mist!
      I can.
      i like that.
      You did ask Will
        They look pretty much identical to the ones I've fitted to both my Surfs. A few minutes with an angle grinder to cut a hole in the rear bumper (in the middle of the Y shaped bracket), couple of holes for the screws, connect the wiring from the old fog light and jobs a good-un. They've worked well, passed MOTs, and survived my off-road driving (which is no mean feat).
        Paul </Slugsie>
        Immortal.so far!
          Will - I've got some like that - really good and you don't smash them off when you're off road!!
            I can.
            oi you behave n go whack ya bush lol
              I fitted one of those about 2 months ago with just a drill and Jigsaw!! easy and not been damaged off road YET!!
                sounds good im tempted
                  Do it Will - go on - do it!!!!!
                    if i had 2 would you see them under wheel carrier n anyone got pics of them fitted
                      Yep!
                        looks good m8 but if you had bigger wheel on back you wont be able to see the one then thinking of putting mine a bit wider that should work
                          I have only got a single one fitted on the right (as per MOT requirements), and it sits underneath a 31" M/T with no visibility issues. Even a 33" wouldn't be a problem.
                          Paul </Slugsie>
                          Immortal.so far!
                            Vehicles driving behind you when it's foggy, tend to be on the ground, not levitating six feet above it!!
                              i could be tempted to get one of those, good find will
