VPN, Any ideas??
  • VPN, Any ideas??
    my woreless printer has stopped working... it keeps saying -
    "the print spooler was unable to coinnect to your printer. This can be caused by your printer being turned off, the cable being unplugged, or being connected to a VPN, which will block access to your local network"
    it's turned on, plugged in, and works for everythinmg except printing!!...
    what's a VPN and how do i remove it??
    VPN = Virtual Private Network
    What it does or how you remove it, I havent got a clue.
    Ken
    [FONT=Franklin Gothic Medium][B][I][SIZE=3]When the going gets tough - Get out !!![/SIZE][/I][/B][/FONT]
      Ken
      i thought it was when you see a girls knickers when she bends over!!
      i can't find anything about it on the computer..
        Nope that's VPL
          it will be a twain driver errer windows xp in not very good at telling you whats wrong
          dont know how well you know windows?
          but to read a path the / means folder
          so go to start
          /my compurter/local disk c:/windows/system32/doctor wattson
          doctor wattson is a hidden file in windows that tells you what wrong with your commy
          follow that path to the folder called system 32
          doctor wattson looks like a pail blue doctor in uniform double click him let it run
          then see what he has to say (let me now the code if any)
          then i will tell you whats best to do (may be uninstall you printer and reinstall it) but it may be fixable yet so let me know
            no faults detected
            copyright 1991-1995, Microsoft Corp.
            hhmmmmm
              do you haveyour printer installed as your default printer?
              have been known to "switch" itself to another printer or fax,when you go to print
              Non intercooled nothing.
                yeah, tried all that... i reckon it's something to do with BT... they sent a load of software with home hub and it's never been the same since.
                  ahhhh i know the problem,its easy to fix
                  get all the bt gumph,put it in a large metal container and soak with petrol.apply a source of ignition.whilst this useless pile of shoite is burning get another isp and voila!!!
                  everything works
                    What????? we've just changed to BT option one!!!!
                      is it an epson?
                      if so go here http://www.ssclg.com/epsone.shtml
                      and run the program
                      it resets epsons to their new status
                      hopes this helps
                      at the end of the day................ it gets dark
                        im sure you will be fine vince!!!
                        we have gone over to sky for sound financial reasons
                        tv phone and broadband for 26 quid a month
                          Have you tried reinstalling the printer drivers ?
                            Yeah, we looked at that too, but it's £26 plus BT rent.
                              This might sound daft but every IT bod will tell ya to do this...........reboot and try again.
