Other things we know:
It's smokier than a rasta at a Bob festival. Although the smoke appears to change. Very much like a rasta.
It has trouble starting, I need to turn it over several times before it catches.
Once running it seems to idle pretty smoothly. Then after driving it often cuts out when the revs drop.
I have run out of my diagnostic powers. (Never really had any.)
My last chance saloon is to do an oil / filter change and fill the cooling system with real coolant and burp it properly.
The last thing I did before I replaced the head: I started the car cold, in the 20 minutes that I was burping the system it over heated and the head cracks opened spewing coolant everywhere. I guess if there is a problem with the gasket, this will happen again.
