My crankshaft pully for the fan belts is fecked. The outer ring has slipped off the inner ring and worn a big hole in the timing belt cover. Does anyone know where i can get cheap replacements for these as i know Toyota will charge me a fortune. Ihave attached pics. Not sure if the pully thing has been referred to as a harmonic balancer. Help, Please!
Disaster strikes
Disaster strikes
Derek :
1990 Hilux Surf SSR Ltd
[B][COLOR=DarkOrange][U]S[/U][/COLOR][/B]ave [B][COLOR=DarkOrange][U]U[/U][/COLOR][/B]p [B][COLOR=DarkOrange][U]R[/U][/COLOR][/B]eadies [B][COLOR=DarkOrange][U]F[/U][/COLOR][/B]ast. Cause you're gonna need them!Tags: None
Originally posted by ElvzCrank pulley is easy to fix. You need to bond it back together with Prism 480 Rubber Toughened Cyanoacrylate. This is like superglue on steroids and costs about £20 from RS Components LtdMaurice
Originally posted by ElvzCrank pulley is easy to fix. You need to bond it back together with Prism 480 Rubber Toughened Cyanoacrylate. This is like superglue on steroids and costs about £20 from RS Components LtdDerek :
Originally posted by DelboyHow can you ensure that it will set centrally and not be of centre and wobbly?
If that gap is less than 1/4 of the width of the hub I'd not worry. Don't know how think the glue is your using, but try sticking it togther, then run some more if the glue into the holes aas it lays on the bench to make sure there is no gap there.
Cheers Tony. Got the stuff today, its as thin as superglue, but apparently would stick your granny to the ceiling if you wanted to do that sort of thing, so i'll give it a go and see
Derek :
Well, i put a good bit of glue around the hub and hammered the bejayzuz out of it until it was almost flush. Couldnt get it to move anymore. Hope it is good enough. Still waiting on a timing belt cover so i cant try it till then.
Derek :
Originally posted by slydogoi delboy get ya dog a new bowl m8 that one looks knackered lol
Got a new timing belt cover from Toyota for €95 after having no luck finding a second hand one. So gonna put it all back together tonight if it doesnt rain. Really miss my baby. Been drinin the GF's 12 yr old Volvo 440 all for a week now. Great car for overtaking, but not a ptach on my Surf. Hope the pully stuck alright and doesnt wobble. Ah well, here goes!Derek :
Originally posted by DelboyWell, i put a good bit of glue around the hub and hammered the bejayzuz out of it until it was almost flush.
I applied for a job but they said i was over qualified. Shouldnt have brought my hammer in!
Derek :
