im losing power now and again . error code 14 flagged up , anyone know what error code 14 is for . cheers.
error code help
IGNITION SIGNAL--NO "IGF" SIGNAL TO ECU
--IGNITER/IGNITER CIRCUIT
--IGNITER AND IGNITION COIL/CIRCUIT
--ECU
anyone care to explain . whats the IGF ???
this is happening after using wvo , also after speeds of 70 mph and above , could the fuel mix be the cause. any help appreciated.Last edited by internetsurfer; 29 September 2007, 19:01.
i broke down the other day after 150 miles , took filter off and it was full of $$$$ , i put a new filter on and only done 50 miles broke down again, took filter off and this 1 looks fine , i think its to do with fuel delivery not being quick enough at high speeds , possibly the pump or injectors are full of $$$$ , truck runs fine though when i change the fuel filter and get her going again and limp home. Just hope i aint foobarred something .
Originally posted by internetsurferi broke down the other day after 150 miles , took filter off and it was full of $$$$ , i put a new filter on and only done 50 miles broke down again, took filter off and this 1 looks fine , i think its to do with fuel delivery not being quick enough at high speeds , possibly the pump or injectors are full of $$$$ , truck runs fine though when i change the fuel filter and get her going again and limp home. Just hope i aint foobarred something .
It should OK as soon as some diesel has gone through the pipes, fill the filter with redex before fitting it.
