That looks a hell of a lot better especially on the 2 door model
Saggy a*se syndrome?
Originally posted by WoodzieNeeds rocksliders
Aye, they're on my to do list too, after the body lift, and although the side steps ain't strucual, they do afford a little protection whilst orffroading
I'm gonna have to chat nicely to all the modding/welding guru's on here to see what I can get done, when, and how much.
My surf's been standard for too long now.Rob
Still working for the man!
Originally posted by plumb bobAye, they're on my to do list too, after the body lift, and although the side steps ain't strucual, they do afford a little protection whilst orffroading
im to busy lolOnly Toyota can get you out of shite
Looks fine mate. There is naturally a smaller gap under the rear arch than the front. Go by the line of the sills to the ground, it's level. If you want the back end sitting higher, just get a set of spacers if you've already changed your springs.Cutting steps in the roof of the world
Originally posted by ApacheLooks fine mate. There is naturally a smaller gap under the rear arch than the front. Go by the line of the sills to the ground, it's level. If you want the back end sitting higher, just get a set of spacers if you've already changed your springs.
Yep, now you mention it, it does look normal, but I may go for some spacers, or possibly LC springs, as would probably work out similar costRob
