Spoiler
  • Spoiler
    Have recently acquired rear spoiler, which needs to be sprayed and fitted, anyone know of anywhere decent in Basildon area?
    Started with a beast now I have a beauty
    they cant be that hard to fit if you can get it sprayed?
    Tim
      Just want to get it done properlike
        I think Ian619 did a fitting guide on it. all the marks an stuff are already there for it.
        spraying, lord knows. To be honest hunt around on the net. its a small item. You could easily post it to a cheap spray shop!
        Ask surfenstein for details on the spray shop he used.
          Cheers mate
            there is a place near me that are good sprayer apparently, if your stuck ill try and get a number cos I need something doing too.
            Tim
              These are the holes you need to drill for fixeing it, plus the one for the harness grommet, theres a cut out in the double skinning already there, drill a pilot hole from inside and dont froget to mask over the outside to stop the drill running off, break light just plugs in there, connector already in place,
              Painting? either get it done at a spray shop, shouldnt be much or get your colour made up into aersol cans, primer and top coat laquer, very light rub down on primer and between top laquer coats,
                Thanks every1 4 the advice, looks like at the very least I will attempt this myself.
                  Had spoiler sprayed by local bodyshop last weekend and bit the bullet and attempted to fix it myself today.
                  All in all, though it felt like ages, as I expected to turn the back end into cheese, really pleased with the final end job.
                  Money well spent, now I'm looking forward to my next mod, most prob will be spots!
                    wheres the pics then ??
                      Covered in muck ready for a fishing trip 2morrow, so once I clean her up over the weekend will get some.
                        Glad it went on ok, not so bad was it? drilling the first hole is the bum clencher aint it? it's gets easier after that
                          if you get it done and have a couple of nuts and washers spare, PM me cos im missing two of mine
                          Oh Nana, what's my name?
                            Sorry managed to attach all 4, even though two upper ones meant that I had to go thru the double skin.
                              Too right!!, had to keep stopping and pysche (??) myself up all the time, in the end just went for it!
