veg oil in a landy?
  • veg oil in a landy?
    OH MY GOD!!!
    only just found out theres no duty on veg oil under 2500litres!! I so want to come back o surf ownership now.
    but while I think on, anyone know if I can run say a 50:50 mix in an l reg landrover defender 90 tdi? if I can, I might just make my dads day.
    cheers,
    Martin
    Just trying to raise my postcount!
    It's a Landy, who cares if it gets $crewed?
    Nil illegitimi carborundum
      If its 93/94 you should be fine! try first 10% then next time 15% until you start noting problems, i would say 60% summer 25% winter. I cant be held responsible for problems.
      Exept the death of a Landrover, I had to tow one out the mud other day with roaxd tyres on!!!
      Without Surf And Unhappy
        yeah i did sort of ask for that having used such a swear word!
        its my dads, and he's a farmer, so just trying to save him some money really. i take it they have fuel pumps that can take it then?
        Martin
          Basically you need to find out whether it is a bosch type pump or a lucas pump. Bosch or nippon or any of that type is very adept for veg oil. lucas takes 5% no more.
          I think L**d R***rs are bosch, will try find out for you.
            Yes providing you step it up gradually watching for sruggle starting you should be fine, even up to 70% when weather is warm
              If it's an older Bosch pump, that is. Newer Bosch pumps, if I remember correctly, are as tolerant for VO use as the Lucas I.P's.
                Good point valid point one that had to be made
                  well the pump is the origonal in a 1994 vehicle
                    So yes it will be ok
                      My Defender is a 2.5 N/A Diesel. Unless they have changed manufactures, his will be a LUCAS CAV fuel pump. Mine is a Lucas CAV fuel pump, part No ERC 6761.
