Like this on both sides then? Pointless - one side suffices - form follows function!
Apache - do you get gasses pulled into the truck through the back window with your exhaust exiting there?
I have got a Stainless Powerflow exiting just below the same spot and I get this, I am going to get it modified to point more at the ground to eliminate it.
A small amout but less than I did with a rear exit. I'm running quite a high percentage veg at the moment (about 75%ish cant be sure as I'm a bit of a slacker) so it's not as noxious smelling as die-sel.
