After nearly 4 years of happy surfing, i'm getting lots of hassle with my car. I had the radiator replaced as it had a split at the top but the new one has gone now as well. The garage took it back off and sent it to be mended but it went again, also it split one of the hoses so it looks like there is too much pressure. However it does'nt overheat. I have replaced the cap and had the pump and thermostat checked. The garage think it needs a new head gasket but after reading the posts on here about the subject I think maybe the head is cracked. They did a gas check with some blue liquid which did not go yellow which would have been bad but it did go green. What do you guys think ? Also how do you get hold of Stevo as the link to yotasurf does'nt work. Hope this all makes sense to you, i'm a bit confused.
Karen
Karen
