i posted ages ago regarding my new steering wheel, and i looked at it propperly these last 2 days.
after sussing that the indicator cancelling mechanism is still there just not engaged by the new boss i thought about how i could get it to be pressed down into the correct position whilst the steering wheel was on, and still get the steering wheel to turn it to turn off the indicators.
so last night we got some old coolant hose that happened to be just the right size, and cut it to about 1cm. this was way too thick and although i had my indicators back, there was some resistance in the steering wheel, and if i didnt have my indicators on and went lock to lock, you could hear and see the rubber just touching the indicator arm and moving it slightly.
so after trimming it off, trying it again, then trimming it off some more and getting it just right by this point there was enough force pressing down between the boss and the mechanism to grip the rubber piece of hose (thats now about 5mm thick)
i felt beaten by it. and was going to try something else. but, if i can super glue the coolant hose to the boss, then bolt it down in the correct place im hoping the cut-outs we made in the hose will be strong enough to grip the mechanism and work as it should!
i remember niftynev saying about how he done his, but at the time i couldnt picture it.
nev is what ive described different to yours?
my mechanism is sprung so that when the steering wheel is off its not never going to work unless its pushed all the way in place. so this is why the new steering wheel does not make use of it, its simply not deep enough by about 5mm
