just had this wacky idea
  • #31
    Just seen the pic you've popped up. The right angle still seems pretty stiff, resistance wise, and is a single point of failure.
    • #32
      Originally posted by MattF
      If you're gonna be doing 'em, couldn'y you shorten the muffler box if it protrudes that far back towards the rear of the vehicle, to make it so that you could V it from the muffler to the rails?
      no i cant do that,the four downpipes meet about a foot infront of the muffler.other wise i would.bit of a bummer really but then nothings that easy.
      www.overfab.uk
      • #33
        the only thing that could upset the mot man is the exhaust exiting near a passenger compartment, if you have a three door no probs but with a four/five door is the problem....
        ttfn
        graham
        • #34
          yea but it wont be a right angle it will be two 90 degree elbows spliced in the middle and welded together.just did the drawing quickly to show you what i meant.
          www.overfab.uk
          • #35
            ttfn
            graham
            i though that but it went through the mot with the side exit exhaust it has on now and that exits just in front of the nearside passenger door.
            www.overfab.uk
            • #36
              Why not half way between the two drawings? Curved pipes from muffler to exit point? Only place you'd have any real angle then would be where it exits the slider.
              • #37
                I asked about that awhile ago. Apparently there's no MOT requirement with regards to exit point.
                • #38
                  ah yea right im following you.yea i can do that.or should i fit a cherry bomb silencer to each bank then take a single pipe to each exit.
                  www.overfab.uk
                  • #39
                    Nice Touch Mark & definately Original... Go for it !!!!!
                    There's always a Payback .... Ya just wont see or hear it Comin !!!!
                    Buncefield Burner
                    • #40
                      thanks for all your input guys much appreciated.i'll give it a go and see how i get on.cheers guys.
                      www.overfab.uk
                      • #41
                        I wonder about you on occasion. It'll be intriguing to see what it looks like, (and how it performs).
                        • #42
                          that makes two of us. ok mate i'll keep you informed.
                          www.overfab.uk
                          • #43
                            ttfn
                            graham
                            the mot regulations state that the sound of the surf must sound like another surf of the same type... there are always bends in the rules
                            Oh Nana, what's my name?
                            • #44
                              Thats OK, it'll sound like another V8 surf........
                              Rob
                              Still working for the man!
                              • #45
                                a 5litre v8 i would of expected a 3" dual system. so 3" each side. but being a custom doubt there is much room. there is ways round this, eg splitting the pipe into 2 each side, but the Y or V creates turbulance.. all depends where your using your power at high revs or not etc..
                                stein want a hand making some stuff? im not bad at stainless tigging
