Hi all , a question. When I bought my 3 rd gen 3.0 TD Surf I asked about towing with the auto box as when I had an automatic Granada I had to have an extra oil cooler fitted to the autobox for towing. I was told that the Surf already has an oil cooler fitted as standard. Is this correct?. if not should I need an extra oil cooler to stop the box being damaged. I tow a twin axle caravan with an all up weight just over the ton and use it all the year round. Are there any points I should be aware of when towing with the Surf as not yet had the opportuinty to hitch up and try it out.
Malcolm
Malcolm
They can be plumbed in to the existing fluid line, cant remember if it's before or after the rad, and It looks like It can just shoehorn in by the bumper and bottom of rad! It's well documented on the USA 4-runner forum although they have mounted the cooler in a different place( Under the sump guard plate parallel to the ground!!!) . I'll let you know how It goes when Iv'e done it!!
