4wd
  • 4wd
    Replaced a joint in the drive shaft today. Before I got the shaft back on, my better half decided she had to go into town. No problem, I thought. 4WD will get us there and back on front wheel drive only. Popped it into low ratio to get off the ramps........and....nothing! Pushed in the button and that worked OK. Drove into town and back no problem in high ratio. I had always thought that low ratio automatically put it into 4WD. Why did it not do this??
    Somebody clever will pop in soon and answer that, but meantime, are you aware that you should not be using 4wd on normal road surfaces. You have no centre diff and on surfaces where all the wheels have a good grip ( like a normal road) you can damage transmission components, diffs and things by using 4wd. I hope it was a short, reasonably straight run into town.
    Bogus
    Сви можемо
      I think he was saying that the rear prop shaft was removed ..........mudsurfer did oxford to poole using 4wd to drive the front wheels only to no ill effect
      The problem happens when driving all 4 wheels together
      www.daemon4x4.org
        Correct. Prop shaft had been removed.
        Andy
          Slinks off into a corner, hanging his head. Reminder to self, read carefully
          Сви можемо
            We all do it ....just hope that trev don't find this thread
            www.daemon4x4.org
              no but I have http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=34106
              Hold my beer and watch this
                It happens to us all, but I did laugh at your answer.
                  in answer to the question i think there is a connector off somewhere do a search for 2wd in lo ratio. i think this is the thread http://www.hiluxsurf.co.uk/forums/sh...&highlight=2wd
