Originally posted by The Lovely Boyo
mini compressor
Well remembered that man!Originally posted by ian619Are you not useing your air con pump now then?, i just refitted mine for the air mod thing, must admit these little pumps look good tho,
I'm not re-fitting the air con pump. It'll mean an extra belt (some power loss) and reduced access around the alternator.
Also, I'll rarely need the air so I felt that having a small compressor boxed somewhere into the boot would be the way to go.
A number of the guys on Yotatech have fitted these and they love em'.Another member of the 'A' team
Gday Joker,
Sounds like a great compressor. Are you for real it only takes a couple minutes each tyre, fooken hell thats fast. Anyway 15psi in the mud should be ok. The tyres shouldnt slip on there rims. If the $$$$e really hits the fan 10psi should be ok but only if its tubeless tyres. I run Bf Goodridge Mud terrain and switched to a smaller 30 x 9.5 x 15. The thinner & smaller tyres go much better off road than the big wide/tall tyres.Harden the Fuk Up Princess
hi mattOriginally posted by hilux2.8Gday Joker,
seing as you put a doubt in my mind thought i'd go and test it let my spare down to about 10 then blew it up to 2 bar no more than two mins
they reckon you can run it for 40 mins
cheers mate
With those specs of yours went down to local arb shop which is a 4wd specialist and checked out some compressors with similar specs. Thanks for the info. Ordered similar one but cost me $150 about 60 pound. I usually use a dive tank with a tyre fitting on but i have to pay for a airfill every few trips. Your compressor sounds good as 10 minutes for all 4 tyres aint bad. Enough time to finish a can of rum & coke while you waitOriginally posted by joker??hi matt
