Hi mate, thanks for the pic's link, some very interesting stuff there, i've a couple of questions, the copper T you made up there, can i ask wot it was for, only i was thinking of makeing summat similar to cut into the heater hose where it sits on the bulkhead, the highest point, thought it might help bleed air out up there, and wot was the second double one for (or was it a rethink of the first one?) thinking about it that might work better for me, bleed and fill!
I've decieded to keep the viscious fan viscious, one go at the screws on the back convinced me to leave the bugger alone, christ their tight, think i'll concentrate on added cooling methods, fans, maybe an extra small rad, etc,
missed a nice alloy raceing rad on ebay, went for £20 and i did'nt have 20 quid,
So wot you running now? the electric fan, you dumped the viscious? is the electric better?, also i was a bit worried about doing the pump shaft in after continual use with the fan locked, ian
That's for the same place, but with the draintap to loop a pipe back to the rad cap opening, so that one can setup a recirculating bleed system. Vince or Chillit has a picture of that method in action.
