discovered something
  • discovered something
    the motor on the elec aerial, is the same as the window motors, just the motor tho not the cog or anything else, might help someone someday
    thanks for that!
    but where is the workaround when a tree has taken my ariel off?
    also, how hard is it to get it out? i might replace mine with a rubber one if they are good
    Oh Nana, what's my name?
      the motor is in the aerial base inside the wheel arch
        Originally posted by tonyppe
        thanks for that!
        Stick a WIPER BLADE in it
          My rubber aerial is great got it from roughtrax. Was a bit of a pain getting it on, only cos of lack of space. Getting the motor out was pretty easy only one bolt held mine in.
            so far then i have 2 bolts. one holding the motor in, and a self tapper holding the aerial in.
            i know when i remove it, to keep it in case the back window or back passenger windows go
            thanks for the info.
