Originally posted by gardener
need advice!
Hi,
I am a landscape gardener. You will need to change the coil springs if they have`nt been changed yet. Has it a towbar, if so check the electrics out. Using the back window is not a problem but you will probably have to access the tailgate and clean and grease everything. I use the rear doors alot for access to my toolbox with the bigger kit on the trailer locked with a chain.
Underslung spare is better but I find swinging the spare wheel carrier fine and it normally clears the front of the trailer unless on a hill. (Dont buy a 2.4td for 3k as you will find a 3.0td for that)
Cheers,
chris
www.protealandscapes.co.ukPowered by Toyota!
