Originally posted by jas69
Under the throttle housing, there is a short, small diameter rubber pipe that's 'j' shaped and has a small plastic valve connected to it. Make sure this little pipe is connected and not dropped off, as they get oil on them, swell and slip off. If it is off then you'll have no turbo boost.
