Driving along last week and heard a loud bang from the rear end (thought I'd run over a brick in the road!) it turns out that a needle roller bearing had failed on the UJ nearest the rear diff. Now I grease my UJ's religiously every couple of months- but it turn's out that this is not enough if one (or more) of the galleries for the the grease flow gets blocked. What happens when you re-grease the bearing, the grease takes the path of least resitance down the clear holes and no grease gets to the blocked one leading to failure. There's not a lot you can do about it other than watch to see if grease comes out of all four quarters of the bearing when you are pumping it.
I dismantled the blown bearing- sure enough in the failed side was a hard clog that no new grease could get past. There were no needle rollers left in the busted side!
Got some new UJ bearings fitted from Roughtrax- at least the Surf isn't shuddering along any more!
