Landcruiser Springs
  • Landcruiser Springs
    If I were to buy Landcruiser springs for the Surf, what model should I be looking at??? Theres a load of choices on Milner's web site.
    I have had new springs put on a few months ago, but really want the back to be a bit higher - I've also installed a Transit exhaust that is much smaller so doesn't keep getting battered offroad but I want the back an inch or so higher after the suspension lift I had done a while back...
    What can I expect in terms of extra lift from L/C springs and what other considerations will I need to bear in mind by adding them?
    Cheers..
    hjd80 springs from milners.but you will also need vinces marvelous drop bracket kit.give him a pm.oh and longer shocks.this should give you a 5"lift on the rear.and you will also need to extend the rear flexy brake line.
    www.overfab.uk
      Cheers mate - I have new ES3000s on the back - what will I need to replace those with???
      So these springs?
      Rear Coil Spring (pair) 003784 44.00
        So these springs?
        well i have +3" es9000s.but i dont have any front or rear ARBs. and yes those are the springs
        www.overfab.uk
          So these springs?
          i put es3000+3" on the rear of mine but some people put the es9000@s on
            So not being all that mechanically minded, can I keep the current ES3000s on - and what do I need to do to get +3 inches from them?
              if yours are standard es3000's they wont be any good so you will need to order +3" es3000's
                Oh right....anyone want some used ES3000s????
                  Are you going for the bodylift also.
                  Iput +2" es3000's on the front of mine but i should of gone +3" all round i think for that little bit more play on the front.I have taken the arb's off the front and rear also for that extra articulation but got a bit more bodyroll which i don't mind
                    my tupansworth.
                    i have es9000+2" shocks with LC springs and havent had a problem, i also havent extended my break hoses.
                    and i give it some sh*t off road, with the rear end cocking a leg a lot and have never had a problem.
                    cheers scotty
                      thats why i opted for the 9000s a bit more stiffer for extra support.
                      www.overfab.uk
                        Nah - if you see the bumper and grille thread, there is a list of what I'm planning to do over the next couple of weeks. Body lift isn't in the plan, but picking the back up a little is. I'll probably put ES9000s on the back for the extra £2 each from ProComp, then I'll need to work out the brake lines from somewhere, and is there anything else before I get started?????
                          just put a spacer and longer bolt under the flexy hose where it is bolted onto the axle.
                          www.overfab.uk
                            i have also got the extended braided brake lines from roughtrax
                              i got that also
