smoke
  • smoke
    Hi all,
    another newbie just got a surf, it smokes for a bit on cold startup,running rough for maybe 10-15 secs,like glow plug out,but checked them and replaced two that were a bit slow seems to be excess/unburnt fuel,does the 2.4 td have an excess fuel/cold start fitted that could be causing the problem
    thanks
    Originally posted by blacktopsoldier
    Hi all,
    thanks
    do you wait till the relay clicks or the buzzer sounds before starting up.Try putting a bottle of redex in 1/4 tank of fuel and give it a good hard drive.
    When were the oil and filters changed last also
      REDEX for DIESELS. I saw a bloke at the Garage using petrol Injector cleaner on his Diesel BMW the other day.
        Hi all,
        thanks
        Hey all just got my surf too and put redex in it, it works a treat stopped smoking now!! woohoo.
        from sexy surf sarah xxx
          Hi Sara and welcome to the home of insane surfers
            Thats two at once ......Welcome to the nut hose both of you
            www.daemon4x4.org
              so it was.i never even noticed.Hi and welcome Barry also
