OK. Following on from my earlier thread wherein I discovered (eventually) that Milners had sent 3rd Gen springs instead of 2nd gen ones, I'm back with another question.
Following advice from an old post, I decided to remove the old springs the (supposedly) easy way by undoing the lower end of the shocks & sway bar & letting the axle drop. All this worked well until I tried to reconnect the sway bar. The axle now seems to have re-located half an inch to the left & no ammount of pushing or pulling seems to make it want to move to the right sufficiently for the sway bar stud to pass through the bush eye on the sway bar itself.
Is there an easy way of re-attaching the sway bar that I'm just not seeing?
Thanks for all the posts on the last thread, btw!
