I've just fitted a 2" suspension lift, while I was doing that I noticed that all four ball joints needed replacing due to the rubber falling to bits.
I got the ball joints from roughtrax and fitted them straight away.
Isn't the shield for the brake disc f****** sharp?
The new top balljoints didn't come with studs so I re-used the old studs.
While fitting them I sheared one and stretched another. I've replaced them with bolts as a temp. measure. What can I use perminantly and where can I get them, as the Toyota dealer said that the studs don't come seperatly to the ball joint?
