shift lever stuck
  • shift lever stuck
    Hi I asked about this problem before, after towing a trailer the shift lever doesn't move out of park when I depress the brake pedal and my brake lights don't work, i was told that a fuse or relay might have blown, so I was wondering where this fuse or relay would be so I can replace it. I had a quick look in both the in-car fuse board and the engine comparment one and didnt find any blown fuses. What am I looking for!!!help! Its a 3rd gen ssr-x. any help would be great. thanks
    Are the bulbs OK in the brake lights?
      He still hasn't answered that since Gonzo mentioned it in the tech section.
      I really hate multiple cross section posts.
        hey matt you know them resistors.............. could it be the pedal switch itself.our sharran suffered from this and it was the actual pedal switch playing up from time to time,renewed the switch havnt had a problem since.
        www.overfab.uk
          What have I done now............?
            www.overfab.uk
              Originally posted by vatchman
              Yeah but, that was different. It was related, but not exactly the same post in two sections. Anyhows, everyone knows I'm a muppet. You had me worried for a second there, when I saw that first line.
                my mates estima has the same problem... he plugged the light board in upside down and forced the plug... now some lights that didn't work before, do work and others don't work...
                i couldn't trace a problem that night so i suggested ripping out and re-wire the towbar electrics and try again.
                  Indicators still working okay, BTW? Managed to collar a flasher relay, (I think), out of a vehicle today, so will be having a peek inside that to see whats needed to make an electronic version. Which, deviating somewhat, does lead to another question. Would this look out of place on the Surf?
                    just trying to ask as many people as possible and get the correct answer as quickly as possible!! sorry it offends you!!!!
                      bulbs are fine by the way, had to go check them hence the reason I never replied to that question! so just wondering what the other options are?
                        Have you tried spraying a whole load of wd40 into the towbar electrical socket?
                        it's in me shed, mate.
                          No offence taken. It's just a niggle when it's already had a valid answer in the tech section.
                            Another option, as Chillitt has mentioned are the towbar electrics themselves. Also, which fusebox(es) have you checked for the fuse? I believe the tail lamp fuses are in the driver footwell fusebox.
                              Does Shirley know about Sharran?
